How to watch tv on pc?
I know that we can make pc to watch tv. I am not talking about watching it online but I am talking about using cable to watch
tv on pc.What changes should I make on my pc so that I could watch tv on my pc?
Hi Thomas
Yes you can watch TV using your pc by buying TV tuner card: this is used to receive TV signals and display received transmission on the screen through a coaxial cable connecter.
There are two kinds of TV tuner cards
1.  Digital TV tuner card: it function by broadcasting an MPEG stream and no encoding device are needed however it helps in the extraction of the PIDs from a transport stream which doesn’t require much processing.
2.  Analog TV card: it has the input capabilities for composite videos or S-videos still can receive FM radio. However thy are capable of encoding tuner data into MPEG format.
Hello dear,
If you do not want to watch TV online, you have to get a TV Tuner Card. This picture there is a TV Tuner Card.
You can control this card via remote. Using this card, you can watch cable TV and more. You can also record on your computer, and capture a VCR Tape to your computer easily. In fact, this little card has a thousand features in it. You will enjoy it. Thanks.
