Immediate help required, actually I have a problem with my mouse it is physically get broken and the only option at present is to use mainframe emulator mouse scroll but have not used it earlier. Please guide me how we can configure and enable mainframe emulator mouse scroll? Is it a freeware or I have to pay for it? Is it compatible with Microsoft windows 7?
How we can configure and enable mainframe emulator mouse scroll?
Hi Alexander,
You have to first set your emulator session to produce or issue the PF7-PF8 on your mouse scroll action which will set the scroll amount for a particular panel. You can follow this step using Quick Windows Sequencer go to Session Options > Mouse > Wheel Functions > and then set your Roll Wheel Up : PF7 and Wheel down : PF8. This can work on whatever value on your ISPF Panel. This is more ergonomic than other options.
