How we can perform port forwarding on Firefox addon?
I want to configure the Firefox to use a proxy, which setting is used to add a proxy to the browser? Would somebody here steers me in the right direction how we can perform port forwarding on Firefox addon?
Answered By 0 points N/A #177141
Hi William Harry,
You cannot do a port forward on Firefox because it is at the application layer of the OSI model, to port forward, you can access your physical layer or your router or simply your router and find the port forwarding option on the configuration of your router, in different cases, if you only have your modem, the port forward function is at maximum state so don't worry about it because you are experiencing the maximum speed of your modem
