How we can uninstall knowledge xpert engine from the laptop?
Is there any un-installer software through which I can uninstall knowledge xpert engine?
Form the last couple of months I was using a knowledge xpert engine, developed by Quest Software. Its primary executable is named as kxpert.exe and it installs about eight files which consume approximately 78 MB of disk space. Till now I have tried various conventional methods to uninstall by deleting files and through add remove options etc. Advise me that how I can uninstall knowledge xpert engine from the laptop?
Best Answer by Huffman Serafin
Answered By 0 points N/A #177243
There is an un-installer software through which I can uninstall Knowledge Xpert engine. You can get this software at the http://www.shouldiremoveit.com/Knowledge-Xpert-25407-program.aspx website. This software program, which was in fact developed by Quest software, has around 33% of its users from America. In Spain and Thailand it is also very popular.
Answered By 0 points N/A #177245
Hi White Harris,
You can uninstall the software by following these steps: first, you have to click start, and then choose the control panel, after which, find the programs and features menu and then the list of the softwares available will be displayed, find the software that you want to uninstall and click uninstall.
