How we remove free avast toolbar?
Hello Raviul Alam ,
If you want to remove Avast toolbar, then right click on the Toolbar and select Customize Toolbar. You may make toolbar buttons visible and invisible by moving them. You move them between available toolbar buttons.
Follow this instruction to remove Avast free toolbar.
Thank you.
To remove unwanted toolbars, you can go to Control Panel and to the "Add or Remove Programs" section and find the software on that particular toolbar, if you don't find it there you can check it in your program files and look for the file, uninstall icon and uninstall it if you want to get rid of it.
Sometimes you can also remove it only in the browser by clicking "view" then "toolbars" after that uncheck the unwanted toolbar, but it will not be erased from your computer only in the internet browser.
Helllo MD RAVIUL ALAM,
You have to uninstall the free-avast-toolbar. To uninstall this you should follow the procedures given below for Windows 7/Windows Vista/:
Step 1: Open “Computer”.
Step 2: Select “Uninstall or change a program”button.
Step 3:Then the window “Control PanelAll Control Panel ItemsPrograms and Features” will be exposed where you will see all the programs that you installed.
Step 4: Double click the program that you wish to remove or select program first and then select the “Uninstall” button.
Step 5: After completion of uninstall of the toolbar you have to restart the web browser program to see the change .
Note:Don’t select the install free toolbar while installing other programs.
With Best Regards
Shifflett Laurel
