How will be Klipsch’s revamped headphones?
Klipsch has revamped its Image One series headphones.
But how is it going to be like?
What extra facilities are added in it?
Hello Julia,
Klipsch has revamped Image One on-ear set. The current Image One is somehow similar to its predecessor, but the difference is that it has been more styled and it as well has got a robust design which is meant to hold up better as time goes by. This new headphones have only a single cable that leads into the left earcup. It has been made using a flat design that prevents it from tangling.
The earcups can be able to fold flat though, and the leather earpads have been made in a way that allows them to fold into the headband coming up with a smaller footprint for storage in a stuffed bag. The earpads have been made in a manner that allows them to provide an enhanced seal as well as better comfort.
Carl
Notifications
