How is will format my computer?
I am using Windows XP, and somehow my PC became very slow. And I know I got lots of antivirus. So, I think I need to format my PC to get clean and also fast again.
I would like to suggest to you to read the information on how to reformat a PC in this site.
Download Link
I hope this will help you.
Dear User,
Thanks for asking question at Techyv. To install an operating system, you need first to collect the Installer CD. When you have it on hand, then please insert it into the CD/DVD ROM Drive, and restart your computer.
At first, please hit Del or F2 button to enter BIOS system for boot priority. First thing to do is to boot CD/DVD ROM, then select and press F10 and save the changes. After doing it you will see a message, please press any key for CD/DVD ROM boot.
Now press any button from your keyboard. Then installation process will start. Please follow the instruction step-by-step, and must reformat C Drive.
Please take note that before reformatting your computer, take all your backup data from C drive.
Cheers!
