jen dessin
Posted on - 02/25/2013
Good day!
To whom it may concern. My Microsoft outlook 2007 has been upgraded to 2010. The problem is that some features has also been upgraded. One of it is in the title bar. I just wanted to know how I will add button in title bar outlook?
Thank you!
How will I add button in title bar outlook?
Hello!
First of all I want to say that you can default method. It’s formed from Tools menu > Macro > Macro it’s very simple method and you can easily do it. If you face problem, you can search for intranet to get diagram of tutorial. In fact, Google is enriched with informative forums. Moreover, in market there are many tutorial books where you would get alternative solution.
Best of luck!
