How will I be going to reset battery acer?
Hello experts,
How will I be going to reset battery Acer? Is there a way to reset the battery pack for I cannot charge it anymore, it will just automatically drain. I don’t want to buy a new one as of the moment. If there is possible solution with my problem, please let me know. Thank you.
Best Answer by Rain Bonnie
Answered By 0 points N/A #179711
When my battery is low and was not able to charge anymore I replace a new one. But if you want it to use in order to save there is a solution to reset your battery and I’m refer you to this site to help you and give you instruction to reset your battery here’s the site http://www.brighthub.com/computing/hardware/articles/50844.aspx
Hope it will help.
Answered By 0 points N/A #179712
How to reset Acer Battery:
BIOS revision 3309 has a fix regarding to the issue for battery charging, yet if you have the newest BIOS and still your battery isn't charging, the best answer is to power down your system, take out the battery and plug out the power cable, next press and hold the power push button for a full 2 minutes to totally drain all remaining voltage from the main board to reset it, after that release the power button, put in the battery and power up the system, it must currently recognize the battery and start the usual charge cycle.
Best regards,
Heather marie
Answered By 60 points N/A #179713
Hi Ava Larry,
regarding with your concern, I have seen some possible answers and solution with it. Instead of giving the procedure, I have decided to just attach the link of the site in which you can read the step-by-step procedure on how to reset the battery of acer.
Brighthub: How to Reset Your Laptop Batteryx
You may also join the discussion in this forum:
Tomshardware Forum: Acer battery not fully charging
Hope that it would be very much helpful.
Answered By 0 points N/A #179714
If your laptop battery does not have a reset button, then follow these steps:
1. Turn off all of your power saver settings on your laptop. This includes your sleep mode and any auto shut offs.
2. Use your laptop, do whatever you have to do, and run the battery down. Ignore any low battery messages.
3. Your laptop is going to die, so be sure that if you are doing anything mission critical save your work.
4. Plug it in and let it get a full charge without turning it on. Not even once. Not even to check your email really quickly.
If you have a reset button then try these steps:
1. Interrupt the battery recharge from step four above after about 1 hour.
2. Hold your power and reset button simultaneously for about a minute, your lights should flash.
3. Turn off the device as normal and finish the c
THANK YOU !!!!
