How will make a new partition with Windows 7 tool?
Hello everyone!
It seems I only have one hard disk in my laptop.
I need to make a new partition with Windows 7 tools.
How will I do this?
Thank you!
Hello everyone!
How will I do this?
Thank you!
You can partition your Windows into two systems.
The first one is where you set up your Windows, and the second one is used by a software.
First system:
1. Run your Windows disk in your DVD RW drive.
2. Install it.
3. Your Windows will ask you where to install it.
4. Click “new” and make a drive.
5. Decide how much space the drive contains.
6. Make your total hard disk partition as you wish.
7. Install the Windows as your preferred drive.
Second system:
1. You must have a software to make the partition.
2. Download the Best Essay software from here. It is a freeware software.
3. Run it and fully install the software.
4. Open it.
5. Select the partition master.
6. Press the right button and select “Create Partition”.
7. Specify the size and location for your new drive.
8. Press OK.
9. You can make as many partitions of your hard disk as you want.
Now, enjoy it.
