How to work on remote computer
Using TeamViewer you can remotely control any computer same as you were sitting right in front of it. TeamViewer working even through firewall. Your partner has to start a small application, which does not require installation. TeamViewer is a very secure way to connect. Depending on your internet connection TeamViewer will optimize display quality and speed. You can copy files to and from remote partner even behind firewall.
GoToMyPC is also one of the best PC remote access solutions. It is powerful enough to satisfy any user giving access to all files and folders going around firewalls and through complex network arrangements.
There are many software available in market which can be used to connect to other computer and through these software you can connect your computer with other computers. Here i am telling you a windows software which comes with windows XP and is used to connect to other computer this software is named as Remote desktop connection to go to this software first go to START and select ALL Programs ACCESSORIES and COMMUNICATIONS and then go to REMOTE DESKTOP CONNECTION here you will see a window when you open it one like this:
Now to connect to other computer you just need the IP of the computer and enter it as shown in the picture and then click on connect. And you will be able to connect to other computer.
Brown tiger.
Hello dear,
It is very easy to work on another computer remotely. For this, you need to use a software. There are many softwares on the market which provide remote facilities. I suggest you use Team Viewer for this. You have to get a USER ID and Password to connect to another computer. Team Viewer must be installed on both computers. When you type the target computer’s ID, it will require a password. Just add the password, and the other computer's screen will be in front of you, and you can do anything on it. Thanks.
