I have been working with Oracle databases since a long time and using a toad to analyze but now I want to reset toad tool due to some technical issue but I am unable to do that please provide the solution on how to work with resetting toad trial version and what are the other ways to do ?
How to work with resetting toad trial version
When TOAD (Tool for Oracle Developer) was developed by an Oracle developer at Quest Software, it used to shareware. But now freeware versions are available not just for Oracle but also for other RDBMS such as Sybase, DB2, MS SQL Server, MySQL, etc.
Please download a freeware TOAD product from this website for your work, instead of using the shareware trial version:
Hope it helps.
Best Regards,
Parisi
