Hello experts,
Good day.
I just want to ask if is it possible for me to convert an audio music to XML form.
Because I am having a hard time of researching about this matter, if any of you knows regarding this matter.
Please do give me some tutorials and links on how I am going to convert it .
Thank you
How would I be able to convert audio music to xml
Hi Kierstenrhiannon,
There is a technique to convert the audio file into music xml format.
You have to convert the audio into cell phone ringtone (.midi) format.
Now, use MuseScore software to convert the .midi file into xml.
Open the midi file and save it as xml format through this software.
This technique may solve your problem.
Hi there user:
Yes. It is possible to do the conversion you stated.
To do this, you will need to download and install an audio converter to your personal computer.
You will need audio converter software that supports a lot of file or audio formats.
You can find a lot of these via on-line, but I recommend ‘Switch Audio File Converter’ which supports 40 file formats. Here’s the link.
Try converting your audio file to these formats (.wav, .floc, .mob, .mid).
Hope this could help.
Best regards,
