How would I create an Express eBook Creation?
Does anyone here know how to create an Express eBook creation? I really need it on my programming class. Please help me with this problem of mine. Thank you so much.
Hi Mycah,
Good day to you. Try to read this, it may help you with your problem. It's not that easy to create an eBook but there are some steps that I can share with you.
The first step is, you need to conduct a product research, which includes analysis. Next thing to do is, create your preliminary documents. This means that you need to construct a table of contents and you also may want to construct a research document but this is optional and the last thing you should do is, you should send your TOC. In addition, you also need a sample of an eBook. This is a short but effective way to create an express eBook. Hope this information helps you. Thank you for reading!
Kevin
Hi Mycah,
Below are some examples, on how to build an Express eBook Creation:
1st step: Product research.
2nd step: Create preliminary documents.
3rd step: Product creation
These are simple tips, in making an express eBook.
Rochelle
