I am currently developing windows application using vb.net. I want to display images in Grid control at a certain website. How can get this vbnet graphic grid control done? Thank you for attending at my concern.
How would I manage to use vbnet graphic grid control?
Hi Rachel,
It is somewhat easy to create a program using VBnet now a days at is now object-oriented.
However, coming from how it is done before you will need a couple of commands and use a command line compiler to check the output.
Showing a graphic grid may be complicated so I found a couple of links to check to know more about the command and the concept.
Kindly click UltraGrid control with dynamic column using VB.Net and How to show a grid on picturebox control?
Hello Rachel,
If you mean Grid control using asp.net, well I got a link that fitted to solve your problem, because vb.net using Data GridView term of it's control for Grid and it seems you mention website so I consider this as an asp.net problem. Check this Link.
Which specify on how to display images inside the GridView control using asp.net.
This is a web application allows you to make a web design for your website personally. It allows you to determine the information structure, they help you keep details such as customer information, image and a design rule. This is a simple process, on your line venture simply just click (SLN tab) to pen visible studio room with your venture rule, simply select the information lines tab and select “view code” this will open a new window where you will be persuaded to enter your rule. The next step is to make a visible basic, key in the rule like this (Repeter1.Item Template = new MyTemplate (); // c# Repeater1.Item Template = new MyTemplate (); Substitute ‘’new MyTemplate’’ name of your design.)
Type the word ‘Data template’, add your design programmatically, simply just click save tab and finally click (Run) to complete the process.
