vhilary p
Posted on - 02/18/2013
Hi there! I have installed a Glarysoft on my desktop, and because of this, redirections occurred.
I just wanted to know how to uninstall this software.
I would put Avast Pro as a replacement. Thank you!
How would I replace my Glarysoft on my desktop?
Glarysoft hijacks internet browsers without the knowledge or permission of the computer owner.
It collects user information, including internet activities and other information, and thus many consider Glarysoft a browser hijacker.
This is the reason most issues associated with Glarysoft come from the Glary virus.
Here is a detailed tutorial on how to remove the software:
I hope that helps.
Hello there !!
So you want to uninstall the application or the software that you have installed into the machine. So for uninstalling the software just follow the basic steps. Assuming that you are using the windows operating system.
1. Press (W+r) key combination
2. Type >> control panel
3. Go to program and features.
4. Select the program to uninstall
5. Click >> uninstall
And here you are done !!
If the program you installed starts giving you problems, the easiest way to remove it is from the Control Panel. Click “Start,” “Control Panel,” and then “Add or Remove Programs.” Scroll down and select your Glarysoft application then click “Remove” or “Uninstall” then follow the instructions. When it is finished, restart your computer then check if you still experience redirections.
If this didn’t fix the redirections you experienced, install your Glarysoft program back. Once it is reinstalled, go to Revo Uninstaller then download and install the free version. Once installed, run Revo Uninstaller then select your Glarysoft program from the list and click “Uninstall.” Follow the instructions to completely remove everything the program created on your computer. When Revo is finished, restart your computer.
Visit Ccleaner then download and install the free version. Once installed, run CCleaner and clean your system. Restart your computer and monitor if you still experience redirections.
