This is related to the microsoft fix it center. Actually I need to know what is the exact functionality of it. As far as I'm using Microsoft softwares is there any kind of relationship or any functionality of all the MS software with fix it center? How should I do automatically the micro fix it center download the latest updates of the all the MS softwares?
Thanks..
How would micro fix it center downloads all the software updates?
Hello Oraliar,
Microsoft fix it center provides automated solutions for your problems and issues. Yes all the Microsoft software are linked with the MS fix it center. There is a list of every type of MS software where you can select the software which is causing problem. It involves three simple steps:
1. Select your problem area. click on the icon you need the solution for.
2. Then is asks what you want to do? Select an activity from the list you want to perform.
3. Run your solution. This will run the solution for your problems.
To go to Microsoft Fix It website please follow the link.Â
