How to write Amharic Fonts on iPhone 4?
Hello. I am using iPhone 4 and I want to know how I can write Amharic fonts on this.
Please send me instructions.
Hi Larry,
You can download iTypeAmharic from iTunes.
It will just cost you $1.99. Once you have downloaded this app, your Amharic keyboard will allow you to write in Amharic as you can see from the below pictures.
I hope this would solve your issue. 🙂
There are two ways to write Amharic fonts in iPhone 4, these are:
1. First is to install the Opera browser to your device. Once installed, type opera:config on the address bar and then tap Go. Then tap the Yes option to allow Bitmap fonts for complex scripts. Tap the Save button.
2. You can also purchase the Amharic app in iTunes. However this option will only work for iOS 7 or later.
