How to write an effective resume in the field of IT Technology
Hi All,
How to write a IT related resume?
What are the things to remember and what all should we put in there?
Abhi.
Hi All,
Abhi.
An Outstanding Resume Must Contain this:
Captivating Design: You need to design a good looking template in order to attract the employer in Reading
Your Name and Contact Information
Your Objectives: Make it simple like "To seek a position that will enable me to use my strong IT-Skills" . Keep in mind that a good objective will often lead you to get hired.
Keyskills: Enumerate your skills, don't include skills that are our of the topic must be related to the job that you are applying.
School/Education: Your school,
Work-experience: This must contain the name of the previous company that your recently worked. Then enumerate on what did you do there. You can place here also your work experience in your OJT times.
Project Experience: Write your Projects that you made during school that are relevant to the job.
Subject:Object-Oriented programming I
Project Name:"Inventory System"
Description: A system that keeps product transactions in a database
Note: It is really advisable that a Resume must only contain 1 page; but if you think that there are things that would be a plus and wont fit into a single page then go for 2 pages.
I Hope this helps
Dear Abhinav,
Some instruction for preparing a resume are given below.
Show that why you are qualified for the specific job
Put perfect keywords and terminology from the IT field
Highlight your strengths that impress the reader
mention details about your experience
enlist the all possible version or image of you
Thanks and Regards
Manik
Notifications
