How to write a lotus script to reset internet password
Hi Colby,
Resetting the internet password using a lotus notes script means you are trying to insert a password on the HTTP password field.
To do this you need to user 2 databases. One would act as an interface where a user can enter their password and the other one to where the value of the information is saved.
You can try to use the code below”
(httppassword_eng is the frontend database field for the password, httppassword_valid_engl is the validation field)
If doc.HTTPPassword_engl(0) = "" Then
Messagebox("Please fill in a password!")
Elseif (Left$(doc.HTTPPassword_engl(0),1)="(" Or Right$(doc.HTTPPassword_engl(0),1)=")") Then
Messagebox("Please do not use brackets!")
Elseif (doc.HTTPPassword_engl(0) <> doc.HTTPPassword_valid_engl(0)) Then
Messagebox("Your password does not match your repeated password!")
Aristono
