manip
210 points
Posted on - 05/17/2011
I have saved all the videos and images from my canon digital camera to my pc. But now I want to write the videos and images to the cd. So, please tell me the step by step process to create a project of my all videos and images onto a cd.
Please help me and I'll be thankful to you for your kind help. Eagerly waiting for your help.
madhup
How to Write videos from my computer to cd using Nero 7
First Installed Nero software on your system, then click on Nero short cut icon from desk top or from start and programs.
After clicking it will display menu, in that so many option like make.
1. Data cd.
2. Make audio cd.
3. Video cd.
Depending on your requirement select option, then you automatically go to data source options.
Here you find add butt click on this add button, now browse window open now add your data.
Now press finish button, after that you press burn after completion burn, you find one alert window "burn completed successfully".
Now click on next button, the cd will come out side of drive, now your cd is ready use.
chevin19
This guide is for burning AVI AND DIVX FILES ONLY to CD/DVD.
1. Open Nero 7. Click on data and make data cd.
2. Press the add button to pull up a browse icon to find you want to save in the CD.
3. Click on your file and press add.
4. Make sure you have the correct file and press next.
5. Press on the little arrow button and select a burning speed. Errors then next press the burn button.
Just wait to finish.
Chevin19
