How you able to shrink videos measurement on a mac?
I have a video file uploaded by You tube.
The video file size is big,I couldn't to do video shrink on a mac.
How will I do the work?
There are plenty of helpful tutorials, videos available which will make you leaner to compress a video file.
Here goes one such video:Â
Hi Patricia,
If you’re talking about YouTube and the problem associated with the file size when uploading, you can shrink the size by changing the specs of your video. Since its YouTube, everybody expects that your video is HD and the lowest resolution for an HD video is 1280 x 720. That is 1280 pixels in width and 720 pixels in height.
The file size for this screen size can also get a little bigger depending on the duration of your video. The longer the duration of the video, the bigger the file size will be. If you don’t want to shorten your video then you have to live with it and accept the big file size.
To help make the file size a little smaller, you can adjust the specs of your video. For 720p HD video (1280 x 720), you can set the frame rate at 30 fps which still renders HD in good quality. Setting it at 60 fps will make the file size bigger. The frame rate or fps sets the quality of the image.
The following frame rates render good quality image:
For the audio, you can get best results and smallest file size at 128 kbps bitrate and 44100 Hz sample rate. You can use the following video conversion software to adjust the file size of your video:
