Hello Experts,
My friend got some flat screen television which is connected to the computer to play Wii and Xbox. We got some problem on how to zoom browser for Panasonic? Can you give us some way on how to zoom the characters on the flat screen television?
Thank you.
Dana Cua
5 points
How to zoom browser for panasonic?
To zoom your browser in Panasonic, you must do the following:
Step 1: Press TV/Video on the remote then TV.
Step 2: Press Menu then the arrows underneath the menu button. Press OK until you get to the next menu.
Step 3: Select Zoom Adjust.
There you will be able to zoom in or zoom out your browser.
Hello ,
Here is the solution you are asking for. Just follow what i say in following two points –
In your Panasonic TV Cable box’s remote control you will find a button in the options – format, zoom, size etc. All the flat Panasonic TV’s usually provide 4 choices when their customer press it they will see the options the aspect button; just, 4:3, zoom and full.
If you set it to "just" then it should (usually) set the picture to the screen size. In addition, Panasonic included a Zoom Adjust feature that allows you to move the screen around when an aspect ratio that cuts off part of the image is selected.
