jporlas
10 points
Posted on - 11/10/2012
This monitoring script sound very useful. Is there any tools that we can use in order to download this monitoring script? Is this monitoring script is available in Windows?
Thanks for the help guys.
Howt to get PHP Server and Ping Monitor Script
Hello Jporlas,
Ping is very useful software which check whether you’re is sever up and alive in the network. You can find thousand of solution for this particular problem. Follow this instruction-
1) Go to Google.com.
2) Search for “ping script for windows”.
Then you will find lots of answer. Choose any one of this and work accordingly. It should do the work.
If you want to download directly, then go to the following link-
http://www.brothersoft.com/downloads/ping-monitor-script.html
This is windows compatible.
Thank you.
