HP 0xc18a0101 Photosmart Printer Problem Solution.
My friend and I decided to buy HP photosmart color printer and got it all decked up in five days. Now, after using it for three days, it is giving me HP 0xc18a0101. What should we do now?
I am guessing that this error is related to ink system failure. I will try to solve your problem. You can reset your printer too.
Solution 1:
Solution 2:
Thank you and let me know if the solution worked for you.
If you have an HP printer and you receive error code “0xc18a0101”, here’s how to fix it. Press and hold the four (4) buttons “OK”, “Cancel”, “Black”, and “Color” then turn the printer off manually. The “Black” and “Color” buttons you need to press are the ones on the copy side of the printer. This didn’t work for some users because they are pressing the wrong buttons.
Allow the printer to turn off normally. Keep holding the buttons until the printer turns off completely. While still holding the buttons, turn it back on after about five seconds (5) then release the buttons. This method should be done twice and the printer should recalibrate. If the error appears when you are installing new cartridges, the same method applies.
First, install the new cartridges on the printer. Once the cartridges are secured, repeat the same steps above to force the printer to recalibrate. This should fix the problem.
Notifications
