Hp 2050 error on cartridge
How could solve my 2050 cartridge read error.
Icleaned all printer sensors,buy new cartridge and it doesn't solve my problem
Hello Tinos,
I have read your concern regarding you HP 2050 printer. As what I’ve understood with your question, the printer is unable to read the cartridge and you want this problem to be solved. And yet, you have tried so many things but still, it doesn’t work. Is it right?
Well I guess this doesn’t need that much of your time. This error usually occurs when the ink cartridge was not used for a while therefor it causes ink to harden inside and requires you to replace it. But before replacing the item, you may try to “REINSTALL” the printer cartridge first then turn the printer “OFF” and the “ON.” If solved, then it’s done but if it does not, then this would be the right time for you to buy replace printer cartridge and install. If already installed, press “OK” to override error and simply continue printing without even noticing that you’ve encountered the error once.
I hope I am in the right track of understanding your concern and gave you a hand to fix the problem. I hope this information is of good help.
Good Luck!
Mali
