danmaersk09
Posted on - 05/11/2012
HP and 3M have merged as what they call "ONE WIRE",purposely produced for simple system to be easily used both in emerging markets and especially during disaster situations, how would this system called "ONE WIRE" help and contribute during calamities?
HP and 3M power desktop PCs ONE WIRE
This system that are developed by HP and 3M which is called one wire is a project on which they collaborated, on which this is a combination of thin client desktop PC and power over ethernet cable to produce a simple system that can be used commercially and during emergency like calamities.
The result is called T410 its a thin client which is powered by a single ethernet cable connected to a powered switch and not from a power cable.This project took about 1 year and half just to perfect the system.Both HP and 3M worked together so that they can make a single cable to deliver both power and connectivity for the computer or desktop while using low power consumption but it can make the computing system running fast compared to other desktop.
