“HP” the best and worst laptops today?
Why is the HP laptops are considered as the worst and best laptops.
Today in terms of Design , Tech Support, Keyboard , Touchpad , Audio , Power , Durability and Display?
Depending upon the various computers or laptops the users generally sometimes give a very positive review and sometimes the review is extremely negative. This is because some products of HP are extremely good, and some products are substandard.
Here’s an example of a much recent model of HP laptop, the HP Spectre x360 15t. The HP Spectre x360 15t laptop ships with 64-bit Microsoft Windows 10 with 3840 x 2160 widescreen resolution and weighs 4 pounds. It runs on Intel Core i7-6500U 2.5 GHz processor, 16 GB RAM, Intel HD Graphics 520 built-in graphics adapter, and 256 GB SSD storage.
For networking, it supports Wi-Fi 802.11ac (2.4+5.0 GHz Dual-band). Standard battery rundown time is 10 hours 4 minutes. For the pros, it has a 4K display and a very slim built. You can also expect a high quality performance from its Intel Core i7-6500U processor plus the fact that it has 16 GB RAM and 10 hours of battery life.
The HP Spectre x360 15t laptop also sports an HDMI and USB-C ports among its USB ports. For the cons, it’s kind of awkward and bulky when using it in Tablet mode. To top it all, the HP Spectre x360 15t model is a quality convertible hybrid laptop which is well designed and built and offers good performance. It is ideal for use either at home or for work.
It allows you to watch movies higher than HD resolution with its 4K display. Suggested retail price is around $1,349.99.
