HP cannot be opened because of a problem.
Hello expertsÂ
I use a latest MacBook Air which is running OS X 10.7 as well as i am using a latest HP Printer (see above).
But the CD that I got with the printer does not support the OSX 10.7; As a result, yesterday I downloaded 10.7driver software (9/21) from the website of HP.
The setup went easily with no troubles.
Then I went into System Preferences and tried to configure the printer for wireless printing as well as there have been no troubles printing wirelessly.
But the problem occurred when I pressed on the HP Utility sign placed on the Dock in the software installation.
Then I found an error that the HP Utility cannot be opened. What is the reason? Please help me to solve it.
Thanks a lot.
HP Utility cannot be opened because of a problem.
Check with the developer to make sure HP Utility works with this version of Mac OS X. You may need to reinstall the application. Be sure to install any available updates for the application and Mac OS X.
Click Report to see more detailed information and send a report to Apple.
