HP CB350 Digital Camera USB Error
Hello There,
I have here solutions for your problem.
*Re-install
Solve a USB error is to follow the steps below to remove and reinstall all USB controllers.
Click on Start
Right Click on My Computer,
Click on Properties
Click on the Hardware tab
Click the Device Manager button.
Expand the Universal Serial Bus controller then right-click every device under the Universal Serial Bus controllers node.
Click Uninstall to remove them.
Restart the computer. It will automatically reinstall the USB controllers.
Then plug the removable USB storage device.
*Check the USB device.
Right click my computer, select manager.
Click Device manager.
If there is a device with a yellow exclamation mark into Universal Serial Bus controllers .
Right click on the yellow exclamation and click install.
Restart your computer.
*Virus
Virus can be the cause of that problem. Virus can affect some hardware. All you have to do is to scan your system using the updated anti-virus. And make sure to update it first before you proceed to scan your system. Update the anti-virus regularly.
*Allow the computer to turn off.
Follow the steps:
Do the same steps for each USB Root Hub in the list.
Right click My Computer
Click Manage then the Device Manager window opens.
Expand the Universal Serial Bus controllers and right click the USB Root Hub then select Properties.
In USB Root Hub Properties dialog box click the Power Management tab.
Check the Allow the computer to turn off this device to save power check box then click OK.
On the Action menu, click scan for hardware changes.
Close the Device Manager window and restart your laptop to recognize the new device.
*Check all the USB ports.
Switch the USB connector to other USB port to check some of it doesn't work or just the other one.
*Add New Hardware Option.
You can try the "Install New Hardware" option to help the operating system recognize the peripheral device. Before you perform this action make sure the device is connected to your PC. Click on "Start" on your main toolbar and then choose "Control Panel" from the menu. When the window opens click on "Add New Hardware" and allow the program to scan for the peripheral device. If it cannot find the device close the window and the reopen it and use the "Add Device Manually" option.
*One more thing to do is, try to check the USB port maybe it become loose. I also encountered that problem. I'm using my memory card reader and when I plugged in, it doesn't work out. So, I just unplugged and re-plug tightly, and then it works.
*Scan for Hardware Changes in Device Manager.
Use the Device Manager to scan for new and recently installed hardware.
Follow this steps:
Go to Start, then select the Run.
Type in Devmgmt. msc and then click OK.
Click the Action tab, then click Scan for hardware changes.
This will make Windows scan & recognize any new devices that are installed.
Close all opened device managers and control panels.
Now, restart your computer and see if your computer detects the USB device.
*Another methods is, do try to check your memory card/HP Digital Camera CB350 in other laptop computer of your friends. If it works, there is a problem of your USB port or on your motherboard.
*You need to update the USB Root Hub.
Go to Device Manager. Expand Universal Serial Bus controllers, then right click all the USB Root Hub and select Update Driver.
This will automatically search the driver that needs to download. You must have access to the Internet.
Hope This solutions can resolve your problem.
