D Manob
10 points
Posted on - 09/07/2016
In the office I work, I have a new HP printer. I don’t know how to handle it. I want to know how to rotate the Pickup Roller and remove it? How to do HP colour laserjet cp2025 roller replacement?
HP Color Laserjet Cp2025 Roller Replacement- Steps To Follow.
There are four major steps to which we can replace HP colour laserjet cp2025 roller.
Step 1: You need to rotate the Pickup Roller. Wait for the ready screen after you turn the printer on. To open the menu, you need to click OK. To open the secondary service, the user needs to press Left arrow and OK at the same time.
For the selection of the secondary service, press OK. To select the Pickup Roller, click OK.
Turn the power off after finishing the rotating of the roller.
Step 2: Removal of the Pickup Roller. Remove the data cable as well as the power supply from the printer and also the paper cassette by resting the printer on it is rear.
For accessing the Separation roller, you need to force white looking tabs away from each other.
Step 3: Removal of the Separation Roller. You need to release the locking pin at the each end to remove the black plastic cover. By pressing the left side and raise the assembly out, you can free the Separation Roller.
Step 4: Installation of the new Separation and Pickup Roller.
You just need to reverse the process.
