Fiannfriday
Posted on - 09/05/2011
In mac operating system I give the print command but when I give this command my system hang.
Then I restart my system then it works properly but when I give the command again then same problem appears again I am very confused about this error please tell me its details solution.
Error:
The HP Communications application is not running. Click the Reset button to restart the Communications application or “Quit” to quit HP Director.
Quit Reset
To fix the problem you have to do the according to the displayed message. First you should have to click on the reset to option the HP provide solution for every error occur in their product. When you click on the reset option. It will go online to the Hp support Centre and their expert will solve your problem.
If you do not want to choose this option you should have to click on the quit option and wait for a while the print job should print it. This type of error are common with printer.
Thanks
You can solve this problem by running the Hp communication application from your applications folder, If you don't have HP communications application the download it from here hp.com. And install it. Once you have install it, Run the application and then try printing. It should work fine. I hope you find the solution.
Peter franklin
