HP DeskJet F380 All-in-one Printer Works with MS Word Only
Hi friends,
Printer is not working at all. All in one HP deskjet F380. It worked fine for about a month. Now nothing. Found "teredo tunneling pseudo-interface" in my device manager. I enabled it and uninstalled it. Now my printer will print from my Word program, but still cant print anything off the web sites. Any help?
Thanks for help.
Best Answer by enrique g e
Answered By 0 points N/A #128045
Go to printers and faxes on the Start menu and make sure that the correct printer is selected as the default printer. You must have a blank check in a black circle that looms on the top right of the icon. If necessary, change the default print device to the appropriate printer, by right-clicking on the icon of the printing device suitable and choose 'set as default'
When printing from a web site, you will see a drop-down menu or a section of "Select printer" in the top-center of the print window that will allow you to choose the printer you want to print.
It is a good practice to make sure it is selected the appropriate printer before trying to print. When printing web pages ctrl+p works well. If you have only one printer can be better right-click and delete the icon of the printer for a printer that you no longer use to avoid problems.
Answered By 0 points N/A #128046
Hello Tyron,
Sometimes new drivers needs for windows 7. To look in the HP web site and to look for the windows controlers 7 for its printer. If you do not work – to open printers and faxes in control panel, click right and choose Properties then go to the card Advanced and choose to print straight to the printer.
But a second like the last option. First 7 tries to verify the most recent windows controlers. If only he(she) has printer it can be a better right click and eliminate the icon of the printer of a printer that I already did not use to avoid problems. Also it tries to update the controlers of printer of HP.
It can use Driver whiz that provides the hardware to him easily control recommended maintenance and help to improve the yield of the PC. Update of the controlers that HP with driver whiz, will see and immediate reinforcement in speed once has updated the correct controlers.
