HP Device Manager – Plug-in Installer
Hi guys,
While installing HP printer on my machine I received an error message. My machine is running with Ubuntu Linux.
Ii has failed to install the plug-in. I tried several times to get it ok through manually but no result.
Have you any idea for the issue? Please help.
Thanks in advance.
HP Device Manager-Plug-in Installer
Plug-in install failed.
Answered By 0 points N/A #192452
Hello King,
As the error message indicates, the HP Printer plugin that you are trying to install is probably corrupted, and therefore you will need to go to the HP website and then search for it from there. If you are using a CD to install the printer, then you might want to go back to place you bought the printer and demand for a replacement.
Nicke
