HP Envy14 Spectre and HPE h9 Phoenix
I heard about the new HP Envy 14 Spectre and Hpe h9 Phoenix launch, what are the external and internal features of these two laptops? How much would they cost?
Hello Jesica Minie welcome to techyv.com The HP Envy 14 spectre is Almost everything you want into this laptop complete Connectivity Bluetooth, 2×2 WiFi and can be set also as a fast and a range of 2×2 WiFi access point using Ad-Hoc.
It has a 13.3 inches of wide screen chassis and about 3.9 pound of weight it is covered by scratch proof glass and a high resolution display with a self opening LCD Flip and about 9 hours battery last.
The system specs of this laptop has a power of a high speed Intel core i5 with 2467M processor a 8 GB of Ram DDR3 Mostly 64bit Operating system may use and up to 256 GB SSD or also called Solid State Disk for very fast performance in reading and loading data. This Laptop can cost over $1400 or higher.
The hpe h9 phoenix is way more advance and if you’re a Gamer then you will going to like this one a tower type cool air flow chassis with a black solid scratch proof glass type of front cover will last long for its always new look. The specs of this system unit are an Intel Motherboard socket LGA 1155 with 4×4 DDR3 slot and 1 PCI x16, 3 PCI express x1 and 1 PCI Express mini card x1.Â
A powerful Intel core i7 with the speed of up to 3.4 GHz for supper multitasking users and a 16 GB DDR3 of RAM with 10600 MB/sec will never experience a single hang on your PC And it has New AMD Radeon Hd 6850 that can make up to four monitor displays plus a 2 TB of HDD or Hard Drive Disk for wider spaces of storage. This type of system unit can cost over $2899.
Hope I've helped you a lot for your question thank you for visiting the site.
Everything is excellent about this Computer. It truly is managed effectively and I recommend this although once you customize this I propose getting these kind of should you be on a budget although would like your computer to operate faster and effectively: 9 GB DDR3-1333 MHz SDRAM [3 DIMMs] — Memory 1GB DDR3 Radian HD 6670 [DVI, HDMI, DP, VGA] — Artwork card AMD Phantom (TM) II X6 1075T six-core processor chip [3.0 GHz, 3 MB L2 + 6 MB L3 discussed, approximately 4000 MHz].
Optional: Wireless-N LAN card (1×1) — only when you got a radio router.
Authentic Glass windows 7 Professional [64-bit] — Much better than Glass Windows 7 home model.
Hope you get benefits.
The HP Envy 14 Spectre laptop comes pre-installed with Microsoft Windows 7 Home Premium and runs on Dual Core Intel Core i5-2467M 1.6 GHz processor, 4 GB RAM, Intel HD Graphics 3000 GPU, and 128 GB SSD hard drive. It weighs 3.95 pounds and measures 0.8 x 12.9 x 8.7 inches. It has a widescreen display at 1600 x 900 native screen resolution.
It supports Wi-Fi 802.11n for networking, WiDi (Wireless Display), NFC, Bluetooth, SD/MMC card slot, 1 USB 2.0 port, 1 USB 3.0 port, Ethernet, HDMI, and mini DisplayPort. It includes 1 year limited warranty. It has a sexy back, front, and palm rest because of the glass casing with backlit keyboard and sunny screen. For the downside, it is quite expensive for an ultrabook and weighs heavier.
The glass casing of HP Envy 14 Spectre is a scratch-resistant glass which wraps not only the screen but the lid and palm rest as well. This makes it the flossiest and glossiest ultrabook. It roughly costs around $1,400. The HP Pavilion HPE h9-1120t Phoenix desktop comes pre-installed with Microsoft Windows 7 Home Premium just like HP Envy 14 Spectre.
It runs on Quad Core Intel Core i7-3770K 3.5 GHz processor, 12 GB DDR3 RAM, AMD Radeon HD 7950 CrossFire GPU, and 2 TB hard drive. It supports Blu-ray reader/DVD writer optical drive, 2 USB 3.0 ports, 4 USB 2.0 ports, headphone and microphone jacks, DVI-D, HDMI, 2 mini DisplayPort, Ethernet, and Wi-Fi 802.11n. It measures 16.22 x 6.89 x 16.34 inches.
The integrated video card supports 3 GB video RAM. It includes 2-year warranty plus a 15-month subscription to Norton Internet Security 2012. It is a great desktop for those who are looking for a cheap ready-made gaming platform. The physical RAM can be upgraded up to 32 GB. It costs around $1,838.99.
