The HP LJ M1530 MFP Series Scan was not found.
Asked By 25 points N/A Posted on -
Hi there,
My father bought a new printer for me and my brother but we have this error. We had some error during the installation of the drivers and I click Skip when was required. Skip and Back were the two available buttons that appeared. Does any have any idea about this? What should I do?
Thanks!
HP TWAIN
Answered By 590495 points N/A #171007
Sometimes the reason why a device, such as a printer, cannot be detected by the system is because of unsupported driver. Even if you connect your printer to your computer but the driver is not designed for your operating system then no connection will still be established. Anyway, for HP LaserJet M1530, the best driver for this device is the HP LaserJet Pro M1536dnf Multifunction Printer software.
Try downloading any of the following drivers for HP LaserJet Pro M1536dnf Multifunction Printer:
On the other hand, if you want to update the firmware of your printer/scanner, download the firmware update from HP LaserJet Firmware Update Utility. If you still don’t have the printer’s ePrint driver, visit HP ePrint Software. To provide your scanner with advanced scanning and OCR functionalities, download the driver from Readiris Pro 12. In case you encounter some problems with your scanner/printer, the HP Print and Scan Doctor will help you troubleshoot the issue.
