HP Mini 110-3000 touchpad issue
My HP Mini 110-3000 touchpad recently stopped working while I was using the system. Not sure if I mistakenly clicked on a button that locked it. Please, how do I resolve it?
Hi
– You can try pressing the FN button and then pressing F9, this should enable you to turn the touchpad on or off
– You could also try to reinstall your touchpad driver in case it was accidentally deleted or has malfunctioned, you can try Synaptics touchpad driver for HP on this link drivers.softpedia.com/get/KEYBOARD-and-MOUSE/Synaptics/HP-Mini-110-3000-CTO-Notebook-Synaptics-TouchPad-Driver-150170-A.shtml
A simple trick is to press and hold on the Function (FN) button and press F9. This will work if your computer doesn't have a FN key. And also, look for the touch pad icon or Synaptics Pointing Device On your netbook and check if there is anything wrong with the settings. You can also refer to the manual of your netbook and check for the correct settings. If you don't have the manual with you, click the link below:
https://www.manualowl.com/p/Hewlett-Packard/Mini-110-3000/Manual/66846
