Hi All,
I owned a HP w1907 lcd monitor. It comes as a package with HP Slim line S3520d Desktop Computer.
I have been using this for the past 2 years, and all is working properly.
Except yesterday when it was running so weird. Normally, whenever I turned the computer off or turned it on again, I don't need to press the monitor's power button at the top of it because it will automatically open when I open my CPU. But since yesterday, I have to run this process again and again. I don't know if this has settings for the monitor, for all I know this is a plug and play hardware that doesn't need any software to run.
The monitor specs are:
Model: HP w1907
Type: Widescreen LCD Monitor with built-in speakers
I searched on Hewlett Packard website, but there is no available software for this. I want to know how I can change it from my original settings. The CPU specs are:
Processor: Core 2 Duo E4700
Chipset: NVIDIA Geforce 7100
Motherboard: Irvine
RAM: 4 GB DDR2
Hard Drive: 320GB SATA
Operating System: Windows XP Professional Service Pack 3
Please help me. I am also experiencing a horizontal green lines appearing sometimes.
Then after doing a reboot, the lines will be gone.
Can anybody state the cause of this problem and what can I do to fix this?
Thanks
HP monitor requires manual restart
Hello Kyleigh Fisher,
I'm afraid to tell you that this a hardware based problem and I can help you out a little bit. At first you have to check some things.
Check out you monitor power cable
Check your Monitor adapter (If Exists)
Check your VGA cable (very Important)
Though your monitor have the capability of plug and play, sometimes windows failed to adjust it, so you can install it.
If there remain problems, please contact to your provider.
This is all I can suggest
logictor
5 points
Hi good day… these issue the flex and the capacitor of the LCD monitor is got a problem… please consult that to the Computer technician to fix the issue…or try to fix your monitor in these following steps.
1. Restart the computer and press F8 during startup when you see “Press F8” in the bottom right corner of the screen.
2. Using the keyboard arrow keys select Enable VGA Mode and press Enter.
3. In Windows Control Panel, double-click the Display icon and select the Settings tab.
4. Use the sliding control to reset the resolution. Manually synchronize the Clock and Clock Phase on-screen display functions. To download a SoftPaq that will assist you with the synchronization, go to the following Web site, select the appropriate monitor, and download either SP20930 or SP22333: http://www.hp.com/cgi-bin/hpsupport/index.pl then find the map of your location. Just download the driver you need.
If this issue will not resolve please consult to Computer Technician in your place to fix the issue.
Thank you, hope its help
Regards;
logictor
Thank you so much for posting your solutions. You are both the best.
