I heard that the HP Officejet 150 Mobile All-In-One is released recently. I want some details about this printer.
Can we use the memory card in this printer?
Is this available in India?
How much is its maximum ppm that company says?
Which is the scanning element used in this printer?
HP Officejet 150 Mobile All-In-One details
HP Officejet 150 Mobile All-In-One is the world’s first printer mobile all-in-one. So you can scan, copy and print while on the go and at your convenience. It has 2.36-inch color touchscreen to manage scanning, copying and printing. The device can print from selected smart phones, mobile phones and notebooks via the built-in Bluetooth. Users can carry this on the road, just like laptops because it has a weight of 6.8 lbs (3 kg) only. Its dimension is 13.98 x 6.95 x 3.52 in (350 x 171 x 90 mm).
The Officejet 150 has 1 USB port, 1 PictBridge and 1 memory card slot. Memory cards that are compatible with this printer are Secure Digital (SD) card and Multimedia Card (MMC).
The printer can handle up to 500 pages when its lithium-ion battery is in full charge. It has the capacity to produce professional-quality documents with the following speed:
Print Speed (Draft, Letter): Up to 22 ppm black / 18 ppm color
ISO Speed: Up to 5 ppm black / 3.5 ppm color
Copy Speed: Up to 4 ppm black / 2ppm color
Scan Speed: Up to 1.7 ppm black / 0.9 ppm color
It scans using the front panel and in single sheet (maximum size of 8.5 x 14 inches). The optical scan resolution is up to 600 dpi.
HP Officejet 150 Mobile All-In-One is anticipated to start shipping in June. It is priced at US$399. However, there is no announcement yet on when it would become available in India.Â
