HP Officejet essential stopped working since win 7 update.
Officejet essential won’t work properly. Has anybody else encountered such problem due to windows upgrade? Tell me how to rectify this issue. Any kind of help would be appreciated.
The drivers for your H.P. The unit is already enclosed within the new Windows Seven Operation system! You don't have to be compelled to transfer drivers to use the merchandise. You need instead to remove the current driver before installing the new one. Follow these steps : Uninstall HP Driver using HP Uninstaller. Uninstall Driver in the Printers Folder.
If that doesn't work out right, As an alternative feel free to go to H.P Home page and refer to Support Options.
