HP Officejet Pro 8600 details
I want to buy a printer for my office. When I search for it I got HP OfficeJet Pro 8600. I want some one to give me its details over its performance.
And I also want some technical details like its performance, Max supported Memory, Transmission speed and Its power consumption.
Hope some one will give me an answer.
Answered By 0 points N/A #135732
HP OfficeJet Pro 8600 is designed to produce professional colored printing at an affordable cost and consumes less energy than lasers, improve productivity of small offices and print from anywhere using compatible Smartphones, notebook and mobile devices.
This printer can aid you to save money because the ink cartridge is reasonably priced but can print more pages than the expensive cartridges. HP OfficeJet Pro 8600 has met the guidelines of Energy Star as it consumes 50% less energy and 70% fewer supplies than laser printers.
Specifications:
Print Speed (Black): Up to 32 ppm Draft, 18 ppm ISO, 5 ppm Best
Print Speed (Color): Up to 32 ppm Draft, 13 ppm ISO, 3 ppm Best
Copy Speed (Black): Up to 32 ppm Draft, 12 ppm Normal, 3 ppm Best
Copy Speed (Color): Up to 32 ppm Draft, 11 ppm Normal, 1.5 ppm Best
Fax Transmission Speed: 33.6 Kbps
Monthly Duty Cycle: 25,000 pages
Resolution (Copy): 1200 x 1600 dpi
Resolution (Printing): 1200 x 1600 dpi black, 4800 x 1200 dpi color
Resolution (Scanning): 4800 x 4800 dpi
Standard and Maximum Memory: 128 MB
Dimension: 19.4 x 16.3 x 11.8 in
Weight: 26.5 lbs
Maximum Power Consumption: 28 Watt
