Hey guys,
I wanted to setup an HP printer driver and I keep getting this error “%1 is not valid win32 application”. I have an image of the screen when this error occurs. Can anybody help me do this without this error?
Thanks in advance.
%1 is not a valid Win32 application.
OK.
HP Printer Installation Error Message
This is a frequently caused error when we try to install any printer drivers from HP.
Try to do in this way.
Insert you HP printer driver CD.
Browse the CD and locate Until folder then go to CCC in Until folder.
First check whether you are installing in a system of HP company or any other brand system.
If it on HP systems, try to run L3uninstall.exe if it's a non HP related system try to run L4uninstall.exe.
Once everything is finished. Install the latest flash from Adobe and then reboot the system.
Once OS comes up start installing the Drivers again.
