HP Proliant DL380 G7 Memory Upgrade In Easy Language
Hi. I am not very comfortable with the computer-related hardware and software. What are the steps for the HP ProLiant DL380 G7 memory upgrade? Please reply ASAP. Thanks in advance.
Hi. For the HP ProLiant DL380 G7 Memory upgrade, DIMM needs to be installed by powering the server off and then extending the server from the rack. Next, remove the access panel and also make sure that the BBWC battery pack or FBWC pack is removed in case it has been installed. Then, remove the air baffle and open the slot latches of DIMM. The DIMM can then be installed. In the next step, air baffle needs to be installed. Also, if the BBWC battery pack or FBWC pack has been removed, install it back on after which the access panel can be installed.
Hope we helped.
Notifications
