HP Proliant DL380 Gen 8 As Well As Gen 7 Drivers
Hi. I am not a computer lover. I want to learn how to install the HP ProLiant DL380 Gen 8 and Gen 7? Please reply ASAP. Thanks in advance.
Hi. To install the HP ProLiant DL380 Gen 8, the first step is to boot the server and during the process, hold and press F10. Next, select the configure option and click on install. Next, the hardware settings of the server can be configured following which the OS which is to be installed needs to be selected.
After this, select the type of installation which can be custom, manual and default. The installation will get completed once the instructions appearing on the screen are followed. To install the G7 servers, first, insert the Windows Server 2012 R2 CD into the drive and then boot the server. Next, to complete installing the OS, follow the instructions appearing on the screen following which the driver needs to be downloaded if there is not any from the section named where to get drivers.
Hope we helped.
