HP PSC 1310 Series Printer In Some Simple And Easy-To-Follw Steps
Hi. I have recently purchased a Mac. I would like to know the steps to install the HP PSC 1310 series printer driver on Mac. Please reply ASAP. Thanks in advance.
Hi. The steps to install the HP PSC 1310 series printer driver on Mac with the help of an Apple software update require you to select the Apple menu and then click on system preferences. Next, select the print and fax option, print and scan option or printers and scanners option as per your operating system. Next, if the name of your printer appears in the list of printers, then, either remove the printer listed and then add the name of the new printer. Then, select the use or print using option following which the name of the printer needs to be selected as well. Then, add the printer to the list by clicking on add. After this, close the window of the system preferences and then print, scan or fax as per your requirements.
Hope we helped.
Before downloading the driver for the HP PSC 1310 printer, check first if your operating system is supported. If you have a Mac computer or you will be installing the driver on Macintosh, you need to check if your Mac version is supported.
For the HP PSC 1310 printer, the driver available for Macintosh supports Mac OS 9, OS X 10.1 Puma, 10.2 Jaguar, 10.3 Panther, 10.4 Tiger, 10.6 Snow Leopard, 10.7 Lion, 10.8 Mountain Lion, 10.9 Mavericks, 10.10 Yosemite, 10.11 El Capitan, 10.12 Sierra, 10.13 High Sierra, and 10.14 Mojave. To download the driver, go to HP PSC 1310 All-in-One Printer series.
Your operating system should be detected automatically. If you see a different operating system, click to change then select your correct operating system. After this, download and install all available drivers and software for your printer.
