I want to buy a scanner for my business use, I looked over a lot of sites.
And I found this "HP Scanjet N9120 Document Flatbed scanner", I want some opinions about this scanner.
Is this suitable for business users, is it fast and reliable?
How much is its daily duty cycle?
And I also want to know its power consumption?
searchbd
HP Scanjet N9120 Document Flatbed scanner details
Here are your product details of HP Scanjet N9120 Document Flatbed scanner :
But I think you can use Cannon for better satisfaction, because it is user friendly with Omnipage pro.
Anyway below are the details of your product :
Manufacturer: HP
Part Number:L2683A#B1H
Type Flatbed scanner
Max Supported Document Size 11.8 in x 34 in
Width 27.2 in
Depth 22 in
Height 13.3 in
Weight 81.6 lbs
Scanner
Input Type Color
Color Depth 48-bit color
Color Depth (External) 24-bit (16.7 million colors)
Optical Resolution 600 dpi x 600 dpi
Scan Element Type CCD
Lamp / Light Source Type Cold cathode fluorescent lamp
Control Panel Buttons Functions Scan,
Cancel,
Copy,
Power save
Duty Cycle 5000 scans per day
Scanner Speed Details 50 ppm – Letter,
40 ppm – black&white – 200 dpi,
40 ppm – Color – 300 dpi
Scanner Features Ultrasonic Double Feed Detection.
Compliant Standards TWAIN,
WIA,
ISIS
Media Handling
Max Document Size 11.8 in x 34 in.
Supported Document Type Plain paper,
Business card
Supported Media Size Details ADF – up to 11.8 in x 34 in.
Document Feeder Type Autoload.
Feeder Capacity 200 sheets.
Storage
Expansion / Connectivity
Interfaces 1 x Hi-Speed USB – 4 pin USB Type B.
Miscellaneous
Cables Included 1 x USB cable.
Microsoft Certifications Certified for Windows Vista.
Power
Power Device Power supply – Internal.
Voltage Required AC 120/230 V.
Software / System Requirements
Software Included Kofax VirtualReScan Professional,
Drivers & utilities,
Readiris Pro.
OS Required Microsoft Windows XP Professional x64 Edition,
Microsoft Windows XP Home Edition,
Microsoft Windows XP Professional,
Microsoft Windows 2000,
Microsoft Windows Vista (64-bit versions),
Microsoft Windows Vista.
Min Processor Type 500 MHz,
800 MHz
Peripheral / Interface Devices SVGA monitor,
CD-ROM
System Requirements Details Windows 2000/XP – RAM 256 MB – HD 300 MB,
Windows Vista – RAM 512 MB – HD 300 MB.
Environmental Parameters
Min Operating Temperature 50 °F.
Max Operating Temperature 95 °F.
HumidityRangeOperating 15 – 80%.
Manufacturer Warranty
Service & Support 1 year warranty.
Service & Support DetailsLimited warranty – 1 year.
The HP ScanJet N9120 Document Flatbed Scanner (L2683A) is best to use for business purposes because it is envisioned to easily establish with a fast environments of everyone that deal with documents. The express scanning from an A3 flatbed and modification of the settings can improve the productivity, effectiveness, document supervision and consistency of the enterprise.
The significant technical specifications are:
This strong and very consistent scanner meets ENERGY STAR policy for energy production. The extreme power utilization is 112W.
The accessed price is US $3,999.
