HP support assistant error during the installation
Posted on - 08/11/2014
I want install HP Support Assistant on my laptop and during the install this error appeared and rolled back the install. I use the same driver as the main driver and is fully compatible with my Windows 7. Does anyone can tell me what this error means ? Why I cannot install the HP Support Assistant ?
Thank you experts !
Feature transfer Error
Error: – 1605 This action is only valid for products that are currently installed
