Green Scott
50 points
Posted on - 10/03/2012
I can run other games but for some reason Pogo games are not working smoothly. It would start (up to the introduction) then will stop in the middle part. Do I need to install or configure anything for HP Touchpad Pogo games to be played? I've read a lot of articles online and their tips did not do the trick.
HP Touchpad Pogo games not working properly
Hi, Green!
I think it doesn't run smoothly on you Touchpad because the game is written in Java. It would have been better if they have written all files in HTML 5 so that it would work on any browser like a breeze. For this problem, may I suggest that you check if you have upgraded your browser or rather your HP Touchpad, if not, please do. Check the plug ins as well, for it may be hindering you from accessing the game.Â
