Davis Avon
20 points
Posted on - 09/22/2012
I just bought an HP Touchpad and I am still on the stage of familiarizing the user interface, the functionalities and the program included in the application. One thing I would like to know is how HP Touchpad yahoo mail update works and how can I enable this functionality?
Hp touchpad yahoo mail update
If you have an account in Yahoo but unable to login through your phone; then you have to update the version of yahoo for your phone. You have to set up the user option manually for activating and using the mail on the phone. Try the process highlighted below to do so.
How to set up Yahoo! Mail to your mobile client using IMAP:
On your phone , press<Home>, then open the Email application.
On the “Your accounts” page, select Next to get started with setup.
Enter your full Yahoo! address and password, then select Next.
On the next screen, you can give the account a nickname and choose the name to display on your outgoing messages. Tap Done.
If prompted, supply the following information:
Incoming Server- imap.mail.yohoo.com
Outgoing Server- smtp.mail.yohoo.com
Incoming Port- 993 (requires SSL)
Outgoing Port- 465 (requires SSL)
Username: full email address ([email protected])
Password: is the password you login to Yahoo! with.
