HP Z1 All-In-One PC System now Available Worldwide
James Mayer 0 points N/APosted on - 04/17/2012
Finally Hewlett Packard launched the HP Z1 worldwide after first unveiled last February of this year. It's been said that this is the world's first all-in-one PC workstation. I am very much excited for this and I want to know, what are the internal components of this PC?
Hello James Mayer,
HP Z1 is already out in the market starting at $1899; it is indeed advertised as the first all-in-one workstation because of its high-end feature. You can easily upgrade parts like replace hard drive, memory or graphics card without tools because of it can easily be opened. Please see the image below:
It is powered by quad-core Intel Xeon processors with ECC memory which means it diagnose and fix internal corruption of data. It has 27” diagonal LED display; it is a large screen that allows better viewing. To see more about the technical specs of this device please click on this link
If you are referring to HP Z1 G2 workstation, check out the full specifications below:
HP Z1 G2
Supported operating systems – HP Z1 G2 comes pre-installed with Windows 7 Professional and also includes a license for Windows 8.1 Pro. You can only install one operating system at a time so just select which version to install. This workstation is compatible with Windows 7 and Windows 8.x
Memory – supports up to 32 GB ECC non-ECC unbuffered DDR3L-1600 DIMMS; 4 DIMM slots
Drive Controllers – integrated Serial ATA interfaces (3 ports)
Graphics adapter – integrated Intel HD Graphics 4400 (for Core i3), Intel HD Graphics 4600 (for Core i5), or Intel HD Graphics P4600 (for Xeon E3-12x5v3). Supports PCI Express video cards (NVIDIA Quadro K610M with 1 GB video RAM, NVIDIA Quadro K2100M with 2 GB video RAM, NVIDIA Quadro K3100M with 4 GB video RAM, or NVIDIA Quadro K4100M with 4 GB video RAM)
Network adapter – integrated Intel I217LM PCIe Gigabit controller (Intel vPro with Intel AMT 9.0) or integrated Intel dual-band AC 7260 802.11 ac wireless LAN & Bluetooth combo card
Available ports – side: two (2) USB 3.0 ports, two (2) Thunderbolt 2 ports (optional), one (1) microphone in, one (1) headset out, and one (1) SD 4.0 media card reader; rear: four (4) USB 2.0 ports, one (1) DisplayPort 1.1, one (1) audio line in, one (1) audio line out, one (1) RJ-45 port, one (1) subwoofer output, and one (1) optical S/PDIF output; internal: USB 2.0 Type A and two (2) USB 2.0 on 9-pin header (used for touch controller)
1....
